  3. Home Assistant
  4. Send/update Value from HA to Node
9 Posts 3 Posters 92 Views 3 Watching
  • E Offline
    E Offline
    esa1966
    Dear,
    I'm a new user of the MySensor Library. Thank for all your work, it is very impressive !
    I successfully installed the Rpi GW and it work with HA.
    I successfully follow example to communicate with a node with a RFM69.
    I successfully realize a Gas Meter and I convert pulse input to meter cube (M3). I transmit value to HA.
    Issue : I suppose that I can lose some pulse and after a period, I need to synchronize the Value in my node with the value on the counter.
    Question : I want to update/adjust the value (M3) in my node.
    Two possibilities :
    1. Add a keyboard + a LCD on my node to adjust the value which is send to HA. Possible for me, but seems too complicated if another solution exist.
    2. be able to send a value through HA. I see a discussion link text but I'm lost and I'm not able to understand what to do.
    E OldSurferDudeO 2 Replies Last reply
    • E esa1966
      Dear,
      Two possibilities :
      E Offline
      E Offline
      esa1966
      Dear,
      With receive function, I can get back information from HA :
      But, which CARD I can use in HA to enter a VALUE or TEXT which can be sent to the NODE.
      Like a SWITCH which can be controlled by HA GUI, but in place to have a ON/OFF, enter a VALUE or TEXT in a BOX ?
      I suppose we can do this but I don't find it....
      Need a bit help.
        // for (uint16_t i=0; i<EEPROM_LOCAL_CONFIG_ADDRESS; i++) {
        //       hwWriteConfig(i,0xFF);
      	sendSketchInfo("GasMeter", "1.0");
        present(CHILD_ID1, S_GAS,"GAS M3");
        present(CHILD_ID2, S_INFO,"GAS SINFO");
        present(CHILD_ID3, S_CUSTOM,"GAS SCUSTOM");
        present(CHILD_ID4, S_LIGHT);
        present(CHILD_ID5, S_LIGHT_LEVEL);
        value = 12347;
        send(msgVOL.set(value));
        send(msgTXT.set("GAS TXT"));
        send(msgCUSTOM.set("GAS Custom"));
        send(msgSTATUS.set(1));
        send(msgTST.set(50));
      	wait(5000);
        if (!initialValueSent) {
          // Send initial values.
          send(msgTXT.set("-"));
          Serial.println("Requesting initial value from controller");
          request(CHILD_ID2, V_TEXT);
          wait(2000, C_SET, V_TEXT);
        if (message.type == V_TEXT)
            Serial.println("Receiving initial value from controller");
            initialValueSent = true;
          // Dummy print
          Serial.print("Message: ");
          Serial.print(message.sensor);
          Serial.print(", Message: ");
          Serial.println(message.getString());
          // Send message to controller
          send(msgTXT.set(message.getString()));
        if (message.isEcho()) // keep message.isAck() for older MySensors version
              Serial.println("Ceci est un accusé de réception de la passerelle");
              Serial.println("Cmd TL 1.a");
              return;
      if (message.type==V_STATUS) // V_STATUS pour MyS v2.0, annulé V_LIGHT.
              controllerState = message.getBool();
              // Write some debug info
              Serial.print("Changement entrant pour le capteur:");
      • J Offline
        J Offline
        JeeLet
        Hello
        .... look around a bit here, maybe good.
        https://forum.mysensors.org/topic/11089/send-a-text-to-node
        https://forum.mysensors.org/topic/10488/homeassistant-mysensors-notify-does-nothing-alternatives
        https://www.home-assistant.io/integrations/mysensors#notify
        Please let us know if you have any test results.
        good code
        • E Offline
          E Offline
          esa1966
          Dear JeeLet,
          I already read those topic.
          But I read it again and make several test again.
          I'm not able to receive a message from NOTIFY.
          ![alt text](2adb2a5f-913a-453c-834f-d925fbe2ba4c-image.png image url)
          I would prefer to have a TEXT box in HA to send a value to a NODE, but is seems such feature doesn't exist.
          For me, it is a standard I use in SCADA system since 30 years.
          We need to put device in AUTO/MANUAL and SET a static value (Valve).
          Or another example is to SET a Setpoint (for a thermostat).
          Maybe I miss something and I have to read a bit more.
          • J Offline
            J Offline
            JeeLet
            "home assistant send a text or value" ---> https://forum.mysensors.org/topic/11089/send-a-text-to-node ?
            https://forum.mysensors.org/topic/5731/resolved-send-text-to-node-with-oled-display/4 ?
            • E esa1966
              Dear,
              Two possibilities :
              OldSurferDudeO Offline
              OldSurferDude
              wrote on last edited by OldSurferDude
              @esa1966 I make the assumption you're node is an Arduino
              Are you using an interrupt to capture pulses? With this code, you might lose a count from time to time but that would be insignificant:
              volatile uint32_t timeOfPulse = 0;
              volatile uint32_t pulseCount = 0;  // a 32 bit number is good for about 70 years
              uint32_t pulseCountCurrent = 0;            // for flow rate calculation
              uint32_t pulsePeriodThreshholdForFlowing = 150;  // pulse period greater than 150 mSec is not flowing.
              #define FLOW_SAMPLING_TIME 1000
              unsigned long flowSampleTimeStart = 0;
              bool flowing = true;
              volatile double flow = 0;
              volatile uint32_t flowCountStart = 0;
              volatile unsigned long flowPeriodStart = 0;
              #define DIGITAL_INPUT_SENSOR 3                  // The digital input to which you attached your sensor.  (Only 2 and 3 generates interrupt!)
              double countsPerLiter = 400.0;             // double and float are the same on most arduinos
              /* DIGITEN G3/4" Brass Water Flow Sensor, Hall Effect Liquid Flow Meter Flowmeter Counter 1-30L/min
               *  n = 6.6
               *  F=nQ L/M (from meter specs)
               *  n * 60  is pulses (counts) per liter yeilds 400 pulse per leter
               *  flow rate 1-30 L/min (from specs)
               *  if time between pulses is greater than 0.15 seconds, there is no flow
               // Pulses per liter
              //-----------------------------------------------------------------------------------ISR onPulse
              void IRQ_HANDLER_ATTR onPulse(){
                timeOfPulse=millis();
                pulseCount++;
              } // make ISR as short as possible.
              //-----------------------------------------------------------------------------------setup
              void setup(){
              	pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP);
              	attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, FALLING);
              //-----------------------------------------------------------------------------------loop
              	uint32_t currentTime = millis();
                // determine if water is flowing
                // if the time at this moment less than the spec threshhold, water is flowing
                flowing = (currentTime-timeOfPulse < pulsePeriodThreshholdForFlowing) ;
                // determine flow during this period and set maximum flow for all periods
                if ((currentTime - flowPeriodStart > FLOW_SAMPLING_TIME) && flowing ){
                  pulseCountCurrent = pulseCount;
                  flow = double(pulseCountCurrent - flowCountStart)*1000.0/double(currentTime-flowPeriodStart)/countsPerLiter;
                  flowCountStart = pulseCountCurrent;
                  flowPeriodStart = currentTime;
                  if (flow > maxFlow) maxFlow = flow;
                if (SLEEP_MODE || (currentTime - previousSendTime > SEND_FREQUENCY)) {
                  previousSendTime = currentTime;
              // MySensors sends here
                  if (flowing) Serial.print("   "); else Serial.print("NOT");
                  Serial.print(F("Flowing"));
                  Serial.print(F(" Pulse Count: "));    Serial.print(pulseCountCurrent);
                  Serial.print(F(" volume:"));    Serial.print(volume, 3);
                  Serial.print(F(" Maxium flow: "));    Serial.print(maxFlow);
                  maxFlow = 0.0;  // reset max flow.
                  Serial.println();
              Having HA send data is not so trivial
              On your Arduino you'll have something like this code:
              #define CHILD_ID1 1
              MyMessage msgCustom(CHILD_ID1, V_TEXT);
              #define DELAY_AFTER_SENDS 500
              bool initialValueSent = false;
              int msgCount =0;
              //--------------------------------------------------------------------------------setup
              void setup(void) {
              //--------------------------------------------------------------------------------presentation
              void presentation() {
                sendSketchInfo( "PROGRAM_NAME",1.0 );
                delay(DELAY_AFTER_SENDS);
                present(CHILD_ID1, S_INFO, "CustomSensor1");
                TextSensor1 will be used as the target.
                YAML script sends "Data from script" to actuator
                alias: SendToArduino
                sequence:
                  - service: notify.mysensors
                    data:
                      message: Data from script
                      target: CustomSensor1
                mode: single
              //--------------------------------------------------------------------------------loop
                  // Send initial message as per Home Assistant docs.
                  send(msgCustom.set(0));
              //--------------------------------------------------------------------------------receive
                if (message.type == V_TEXT) {
                  // Dummy print
                  send(msgText.set(message.getString()));
                Serial.print(F("count: "));Serial.println(++msgCount);
                Serial.print(F("Type: "));Serial.println(message.getType());
                Serial.print(F("Data: "));Serial.println(message.data);
                Serial.print(F("Long: "));Serial.println(message.getLong());
                Serial.print(F("Float: "));Serial.println(message.getFloat());
                Serial.print(F("Sensor: "));Serial.println(message.getSensor());
                Serial.print(F("isAck: "));Serial.println(message.isAck());
              The commented out code starting with "alias" is the YAML script that will be used to send your data. Note that in this example, "Data from script" is the data that will be sent.
              One annoying thing is that the service "notify.mysensors" can't be found until after you've run the Arduino code. But then, now that you know what the service is, you can probably just put it in your code and see what happens.
              Good luck
              OSD
              • E Offline
                E Offline
                esa1966
                @OldSurferDude
                Correct, I use a node based on Arduino.
                I'm not able to sent a message using MYSENSORS
                My Node :
                I'm not sure how to format it :
                But, I'm able to see it works with MQTT.
                In my code, I add this : request(CHILD_ID2, V_TEXT);
                The receive function is like :
                I receive a message : Received a message: GAS TXT
                So, I’m sure the arduino sketch is working and HA send a value correctly.
                So, the problem is that I don’t know how to format and send data using MQTT ‘My Sensor’
                To understand the format, I search in LOG to see how it is formatted :
                Line 14260: 2023-01-01 19:38:44.666 DEBUG (MainThread) [homeassistant.components.mqtt.client] Transmitting message on mysensors-in/2/2/1/0/47: 'GAS TXT', mid: 18
                So, I use MQTT to do the same :
                This is the SERIAL output on Arduino Node :
                Conclusion : I have a workarround.
                Question 1 : Do you think possible to use MYSENSORS NOTIFICATION ?
                Question 2 : Is it possible to have a OBJECT in the dashboard to send a value using the MQTT ?
                • J Offline
                  J Offline
                  JeeLet
                  wrote on last edited by JeeLet
                  a test with a numerical value
                  int val = 850 ;
                  #define val_CHILD_ID 8
                  MyMessage msgval (val_CHILD_ID, V_PERCENTAGE);
                  //----- reception MyS   ------------
                        if (message.getType() == V_PERCENTAGE) {
                        if (message.sensor == 8)
                        val = atoi( message.data );
                      send ( msgval.set(val) );
                  • E Offline
                    E Offline
                    esa1966
                    Thank.
                    This is what I do for the receive :
                    So, I'm now able to SET a VALUE from HA.
                    And after a pulse it is updated
                    My question is most about how to use HA to do it more easily as possible.
                    Do you think possible to use an TEXT object which can be sent to node through the MQTT ?
                    Second question : how do you send value to the node (MQTT or other ?)
